i currently have a sling lift for my 20ft searay select ...
it has 2 slings approx 10ft apart ...
if i pick up an sv211 .. i'll need to probably adapt my current lift such that i remove the slings and somehow come up with a system to use the lift rings (shallow water ...won't be able to have a dual runner type lift ... can't use sling with the drive shaft on a direct drive or v drive, hence need to use the lift rings)
Firstly ... is it REALLY safe to do so?? I was supprised that correctcraft acutally recommends this ... is it for real?
So ... anybody have a similar challenge ..any pictures on how to adapt it ...i assume i'll need to get some type of support adapter made?
