Trans Fluid Change
  • jonsquatch
    • Jul 2012
    • 251
    • AZ
    I use a air operated one from harbor freight like this http://www.harborfreight.com/6-1-4-q...tor-46149.html that I have had for about 6 years now. I replaced the line on one of the probes with enough ice maker line that I can leave it sit on the ground and still use it and it works great. I know a lot of people say to avoid sticking plastic lines in the transmission so they don't get stuck in there, although I haven't had any problem with the ice maker line.
    • Onside135
      • Apr 2014
      • 7
      • N/A
      • 2001 Ski Nautique 196
      Thanks for the recommendations. Those look like some fairly serious pumps. I was hoping for something a little less expensive that might do the trick. Probably some sort of minimalistic hand pump...anybody using one like that?
      • shawndoggy
        • Aug 2011
        • 151
        • Reno
        • MB Sports TWB 23
        Originally posted by vision View Post
        Make sure to check PCM's recommendation for your transmission based on year. PCM recommends NOT changing transmission fluid on newer transmissions. It is because of the reasons stated above.
        This is inaccurate (though I came to the same erroneous conclusion). The manual is poorly worded, but the part where they talk about not changing is actually referring to the vdrive not the transmission.
        • vision
          • 530
          • NC
          • 2013 G23
          Thanks shawndoggy for the clarification! I will relay to the PCM mechanic that told me to not change the transmission oil, only to check level and for contamination.
          • shawndoggy
            • Aug 2011
            • 151
            • Reno
            • MB Sports TWB 23
            No prob. I made the same mistake.
            • eyekode
              • Aug 2013
              • 25
              • Apex, NC
              #21
              I have one like this: http://www.amazon.com/gp/aw/d/B000GU...&pi=SX200_QL40
              I like that the hose is hard/rigid and small. Great for poking around to find the lowest spot in your transmission.
              Salem
              • aZ`
                • Apr 2013
                • 154
                • Australia
                • 2008 210
                #22
                Sorry for the thread dig but the topic remains the same.
                After owning my boat for one year and about 100 hrs I decided to change the trans oil. I was told it had just had a major service prior to purchasing so assumed trans oil would have been included, my mistake.
                Basically for those who are saying that old oil should not be replaced 100% with new, what would you do here? I'm wondering if it's ever been changed in it's 330hrs.
                2008 210
                • vision
                  • 530
                  • NC
                  • 2013 G23
                  #23
                  I would change 25% every 25 hrs for 4 changes.
