Alright Guys, who ever can figure this out is a true winner.
Here is the deal. I have had these electrical problems and boat hasn't started for a few weeks. Very sad sad situation. What happens is that when i press start after punching in the code the system shorts and the cumputer shuts down. I hear the perfect pass beep beep consistently when putting the ignition in start mode (after activating the computer i press start a second time to turn the guages on, this is when the perfect beeps every 3 seconds or so).
COuld it be that the perfect pass is acting up. All my connections are solid, no blown fuses, solenoid and starter seem to be in tact and all the grounds even on the battery are rock solid. I hear the starter click which i go to start right before the system shuts down. This makes no sense to me but is definitely something electrical.
What do you all think it could be. I just noticed the perfect pass issue once i had the boat out of the water. I cant even turn the perfect pass off once its beeping. Seems like it has a mind of its own now. as for the engine everything ran A1 when it was going.
Let me know what I should do as the next steps ....
