Leaky deck / hull joint... what is the proper repair?
  • aztaco
    • Sep 2006
    • 33
    • SLC, UT
    So last weekend out in my '02 super air I found I had water coming in (I assume from the deck/hull joint). Water was running down the passenger side of the boat by the cup holders. This only happened when heavily loaded and making tight left-hand turn at the end of our line (much tighter than normal due to a narrow cove at the end of our line).
    I know I've seen others here have the same issue, but have not been able to find the resolution. I assume the easy fix is find the offending area and seal it from the backside with caulking of marine sealant. So my question is, is this the proper fix? If you have done this, have you had to re-apply the patch? Would removing the entire rub-rail and inspecting / repairing the joint form the outside be be overkill?
  • OKWAKEBDR
    • May 2005
    • 750
    • Lakefront
    • 2017 Super Air Nautique G23
    Had the same thing on my '05. The dealership resealed the entire deck/hull all the way around under warranty. I'm not sure if this qualifies under the lifetime hull warranty or not. The water was coming in under the rub rail. They just resealed it there on the outside of the boat all the way around.
    Current: 2017 G23
    • ers906
      • Feb 2010
      • 921
      • Phoenix AZ
      I had the same problem, but it wasnt from the joint so much as it was from the rivet holes used to attach the two sections. I removed the middle portion of the rub rail and silicones around the length of the boat. Solved the problem
      Eric, Phoenix AZ
      G23 550 hp (finally here)
      2002 Super Air
