Tuesday I plugged in to the 12 volt outlet and it wasn't working, I thought it was the pump that I was using so I didn't worry too much about it and we stayed on the water. Well it's not the pump. I see in the manual it says thee is a 10 amp breaker for these, where is it located? Is there anything else that breaks/corrodes that I should look for?
12 volt outlet broken
19 SANTE 210
08 SANTE 210 ZR6
08 SANTE 230 ZR6
88 Baja Ski Sport- First boatTags: None
- Feb 2010
- 921
- Phoenix AZ
- 2013 G23 550 hp (ordered and awaiting delivery) 2002 Super Sport (coverted into a SAN) 330 hp Excaliber 1994 Sun Tracker Party Barge 115 hp 1989 Horizon 200 Four Winns - sold 1989 Regal Commodore 280 - previous Possibly looking into picking up a 70'2-80's Nautique to rebuild as a ski boat
In my boat the breakers are labeled on the kick panel on the drivers side feet. I would check that first. Afterwards, I would pull the outlet itself and look at the connections. Use a voltage tester and see if you are getting power to the outlet if the breaker is good.Eric, Phoenix AZ
G23 550 hp (finally here)
2002 Super Air
Outlet
Could be the breaker, but just in case, there is a 12v button on the dash pod that is supposed to send power to the outlet (based on my reading of the owners manual) but in my experience, the button does not have to be pressed for the outlet to be hot -- but it could be worth checking.2010 Super Air Nautique 210 Team Edition
- Feb 2010
- 921
- Phoenix AZ
I never understood what that button was for. I have never pressed it and I have always hat "hot" outlets.Eric, Phoenix AZ
2002 Super Air
- Feb 2010
- 921
- Phoenix AZ
I think that it is an on-off switch that can be used for any 12V accessoryEric, Phoenix AZ
2002 Super Air
Check the wiring to the outlet. When mine came it was hooked up backward. Possible a wire has come off. Multi tester and you will have it going in 10 minutes.2018 200 Team H6
2009 196 Team ZR 409
2005 196 Limited ZR 375
2003 196 Limited Excalibur
1999 196 Masters Edition
1987 ProStar 190
Thanks guys, I had quickly checked the fuses on the kick panel, I'd assumed these are more breakers and not fuses and when they pop they stick out. none of them were sticking out. but I wasn't super thorough because I really thought the pump had died. So I'll double check them. 12V button on the dash? I've never noticed it, but I'll check that too. It was really strange because I'd used that outlet earlier in the day, that's why I really thought the 15 year old air pump was the culprit not the outlet itself.
My wife has Labor day plans that doesn't involve boats, so I'll probably won't get back out to it until next week.
Thanks for the advise so far.19 SANTE 210
08 SANTE 210 ZR6
08 SANTE 230 ZR6
Made it back on the water last night. I was just the breaker by the kick panel. interestingly I dont have a 12 volt button on the dash pod.
Thanks for the help!19 SANTE 210
08 SANTE 210 ZR6
08 SANTE 230 ZR6
