Does anyone have any insight or infomration regarding 2 potential problems that I am experiencing with my 2006 SV-211?
1.) At the begining of this season, the steering wheel/cables/rudder where "locked" in position. This had never happened before over the off-season. I was able to free the steering system with a firm tug of the steering wheel. Also, I have notices that the steering system begins to lock up if the boat sits for more than 3 weeks. Is this a sign that the steering cables are going bad and need to be replaced? Is there a way to lubricate the steering system so this wont' happen?
2.) I was tubing some teenage kids last trip at higher speeds (around 28 or 30 mph) and was driving in a "S" pattern on flat water with a relatively light boat load (i.e. low on fuel and few passengers). During right turns only, the steering would become very stiff at the same time that the prop appeared to be cavitating. This wouldn't occur at slower speeds and I couldn't get the this to happen with a heavier load in the boat. Was this simply prop ventilation/cavitation brought on by a "balence" problem in the boat during this run? Why only on right turns? Does this occur on other SV-211's?
Thank you for your help.
