I had my 98 air at the lake for the first time this year....all seemed to be running fine until I decided to throttle up to about 32mph........it seemed to be running fine, motor sounded good and then all of the sudden the engine died........i immediatedly opened the engine box and saw a little bit of smoke...not much and the motor seemed really really hot......
when i was at full throttle my oil pressure was around 50 psi and temp showed around 160 degrees..... i sat there for min temp went to 170..................but nothing higher.........i wonder if my gauge was stuck or something..
oil is at the correct level and looks good
try and turn the engine over....and would not start.......try again , and then again and then again........nothing..
i wait another 5mins and finally get the engine to turn over...but dang does it sound rough.......it is idling sooo rough like it wants to die... sounded like it was gasping for fuel and i heard some weird noises...loose noises from the engine ever soo often........i make it too the dock and do not kill it untill trailerd.......havent tried to start it again..
does this sound familiar for anyone.......anyone have any ideas?
