Hi All,
I was out on the lake today with my brother and nephew and there is something majorly wrong with the electronics and the boat wouldnt start and we had to get towed in.
Ill explain the situation as whats been happening. A couple weekends ago i went out in the boat and turned it off. When I went to restart it just went "Beep". I shut it off on the master and renetered the code and pressed start and it clicked again. I then pressed start again and it registered and started. When I went out today she started perfect. I pulled my nephew and then shut the engine off. Went to restart and "click" whole system would shut down. When it was on and now i press blower or any other button it worked, but then wouldnt work. Its either the system all works or it shorts when i press any button. At times when I restarted the main power with the master code electronics all worked, but as soon as when i press start the whole stystem shuts right down. Its really as though its shorting. I have lots of power. here is another hint . when I press start the second time to activate the guages it would work 50% of the time and when it did the engine light is on (dont know if this is normal prior to starting) and the system beeps twice in a row. Also the engine would click as if it wants to start.
In general i think its a short, but not sure how to check the fuse box and where the right places are to check. The fuse box under the steering looks different to what I am used to so I dont know how to test it or check it.
ANy help or ideas and suggestions would be great. Especially if someone has been through this as well.
Thanks Guys !!!!!!!!!!!
