So here's a challenge for the group. This has happened three times to me and I can't definitavely figure it out... I think I either have a bad blower motor that draws too many amps or a bad 50A breaker. This only happens with the blower on but I think it will happen with the heater on as well.
Last weekend we were out on the water and I went to re-start the boat with the blower on. I heard a "pop" like a breaker being thrown and then I was dead in the water.
I tried to diagnose the problem and here is what I found:
- I lost power to my dash. Voltmeter shows ~4V between the hot wire and the ground.
- I was showing ~4V between the hot/red side of the solenoid and the block.
- Battery was showing 12.4V.
- I cannot "reset/push in" the 50A breaker button that appears to be popped out farther than the 12.5A breaker at the back of the motor.
- When I disconnected the battery and reconnected it I got all my goodies back and was able to get going again.
I have the 5.8 Pro-Boss with the Pro-Tec ignition.
Any ideas?
Any ideas?
