I have an 03' Super Air. The problem I have is intermittent and can't seem to figure out where it's sourced. The problem is that occasionally, the boat will cut out or Perfect pass will cut out, it seems to be worse when the heater is on, hence the idea of putting relays in place. So, I'll have a low voltage reading on the dash and if I hit a double up, Perfect Pass will cut out or the boat will cut out. I checked every connection in the boat, nothing is loose. So, I'm trying to isolate it best I can.
Chris
Chris
