Sounds like at the water pump in front that there is a loose marble in it and it makes more noise as rpms increase. I am assuming that the water pump is bad? The sound is very close, but not exactly with rotation/rpm and some bounces of the marble are louder than others. I can't tell for sure if it is water pump or cam shaft below it, which would be much worse. Any help would be appreciated. I just got it out of storage due to crazy work schedule and then this happens. Engine only has 100 hours on it and it is a 2002 year motor.
If water pump, any idea on reasonable cost for repair?
Thanks a bunch for all of your ideas and opinions in advance.
Happy Boating.
Happy Boating.
