Up until about 2 weeks ago, my sport has been running flawlessly this season (my first with this boat). Starting two weeks ago, my wife and I went out for a ski, the boat started right up. I jumped in the water and(never shut the boat off at this point) skied a few sets. My wife shut the boat off, I climbed in and after she was in ready to go, I went to start the boat and my dash came on but the boat wouldn't turn over. I also heard the clicking sound like you would hear if your battery doesn't have enough juice to turn over. Of course for the first time ever, we were the only boat on the lake, so I was forced to call the marina on the lake to have a mechanic come out. The guy that came out didn't like how my battery was hooked up and thought we should have a marine battery not a car battery. Reason being, there is a splitter connecting the motor and the amp to the positive and negative. The battery is 800cca. This mechanic said that he thought I had a power leak at the battery because of the extra components and the fact that it was very difficult to tighten everything down the way it was currently set up (this is how I bought the boat). He went over everything and tightened it up best he could. But it still wouldn't start. He went to the back and noticed the power connection to the solenoid was a little loose. He hand tightened it down (he didn't have the right size wrench to tighten it properly) and I was able to start the boat. Since then, I have tightened that connection to the solenoid and went back to the battery to see if I could tighten anything more. I did notice that the positive connection can be moved a little, but I cant get a wrench in that space to tighten it any further...its like the nut goes to far into the connection on the terminal? We went out to ski yesterday(the first time since the issue began) and the boat started, although a little sluggish...like there almost wasnt enough power. I skied, then we turned the boat off. When my wife got in to ski, the boat started right up. After she skied, we turned it off. We then started the boat again to move to another area of the lake to hang out. After that, the boat was off for about an hour. When we went to leave the boat wouldn't start, we could hear the clicking sound of a dead battery again. The only thing I could think was to try and tight that positive connection on the battery that i know was slightly loose. I was able to get a very slight turn on the connection. After a couple turns of the key the boat started ( a little sluggishly again).
Does this sound like a power leak? Would it better to have a marine battery that would have terminals for the motor itself and the amp? Or at least find a way to get all connections tightened down better? Could the solenoid be bad? I do hear my fuel pump come on also, so I would assume its functioning properly. Any other thoughts out there?
