Best way to restore colour gel coat
  • Dave210TE
    • Apr 2010
    • 45
    • 2006 super air 210 TE
    Hi there i was just wondering what is the best process to being back the shine in my lime green 210, the green has started to fade a bit and i want it back looking like new again?
  • mhaaland
    • Jul 2007
    • 217
    • Des Moines, IA
    • 98' Air Nautique
    i just got done restoring my 98' Air and i used the wetsanding, buffing then polish method. Your boat is much newer so i would imagine you'd be able to skip the wetsanding.
    For the buffing I used a Meguiars Fiberglass Restoration kit and used the oxidation, stain and scratch remover compound #49 then followed it up with the polish #45.
    Some people on here have used the 3M "finesse It" compound for buffing.
    FCT 2 by NDT
    Teak Platform Restoration
    Re-Carpet Trailer
    Oxidation Removal
    Re-Decal Boat
    Interior Restoration
    • cain0725
      • Apr 2010
      • 37
      • 2004 210 Super Air TE
      clay bar fix
      Go to any auto store and buy a :claybar kit and follow the instructions,, very easy and will look awsome, wont harm your boat like wet sanding can if you dont know what your doing..
      • hourglass
        • Mar 2010
        • 248
        • lower bama
        • 2005 SANTE
        i think i have 3M one step wax. it's a slight oxidation/wax compound. it turns out great just doing it by hand. i know west marine carries it.
        • Dave210TE
          • Apr 2010
          • 45
          Ok guys thanks for the tips.
          • GoBig
            • Apr 2008
            • 551
            • Santa Cruz, CA
            For minor oxidation, no need for wet-sanding. You can get it pretty close to showroom with these 4 steps:
            Step:
            1. Wash boat
            2. 3M Rubbing Compound (acts like wetsand, removes oxidation)
            3. 3M Finesse-It II Glaze (removes the swirl marks)
            4. 3M Liquid or paste wax (makes it shimmer!)
            I did this on my '03 this year and the results are pretty phenomenal.
            2003 SANTE
            • bobchris
              Banned
              • Apr 2006
              • 359
              the clay bars will not remove oxidation read the instruction label
              • xlair
                • 694
                • Wisconsin
                Yea a clay bar is absolutely the wrong thing to use, it won't do anything. You need to use a compound with a mild abrasive and a buffing wheel to bring the shine back w/the most effective results. It really depends on how badly oxidized or scratched your surface is.
                2001 Pro Air Nautique
