have 2000 SNOB gt40 EFI - runs great - all tuned up, new fuel pumps, filter, plugs, cap,, wires rotor etc- we ski everyday and it runs great all day but the idle is too low in gear( 580 -600rpm, supposed to be 650) and sometimes it is hard to start when hot .....sounds starved of gas when it is cranking.......if I start with a little throttle it will start....or maybe not...if I let it sit it will start. Does not run hot.
........................do I simply tighten the idle control screw on the engine until baseline rpms go up or should I look to replace my TPS,MAP sensors etc. Good fuel pressure(35psi) at the FCC. Could it be a fuel sensor relay going bad? I already bought a spare relay but have not installed it. Ethanol in my gas ? Sometimes if I disconnect the battery and reset everything - she starts just fine. Any help would be appreciated. Thanks
