I have two questions.....
First, I am considering converting to electronic ignition for my 1996 Ski Nautique 176. It has a PCM Ford 351. Does anyone know which kit would work best? If you can supply a brand and model number that would be great.
Next question (unrelated to the first)......
When starting my boat (the one mentioned above) for the first time, when launching, it starts fine. It usually starts up on the first turn of the key. However, after it the engine is warm it takes two or three times before it will start. I usually turn the engine off when changing riders. Therefore, it's a pain to start the boat again for the next set.
A friend of mine had this suggestion...... He said it sounded to him like the choke was open when the engine is cold, thus starting on the first try. After the engine warms the choke is not opening up enough, thus making it hard to start. Does this sound like it could be the problem?
If so, the carb is an area that I don't have much experience with. Can anyone tell me how to go about adjusting the choke?
Thanks,
Richard
Thanks,
Richard
