'00 SANTE Ballast Re-Do
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    Originally posted by bchesley View Post
    I have timed them both ways and sitting or on plane at 25mph they fill will within 30 seconds of each other.
    Scoops? or flush intakes?
    the WakeSlayer
    1968 Correct Craft Mustang
    • wcherashore
      • Sep 2009
      • 190
      • San Diego, CA
      I am adding a second thru hull to supply water to two pumps in my 2000 air. What is the current factory thru hull used? I'd like to supply both pumps with the single thru hull.
      Thanks.
      • TexasAg01
        • Mar 2009
        • 36
        • Dallas, TX
        • 2000 SANTE
        Thanks.
        Not sure the exact one their using on the brand new boats but I'm planning on getting one from www.buckalgonquin.com
        You can also referrence this install. http://planetnautique.com/vb3/showth...allast-Install SkiKing did a GREAT job at documenting it and he has a few pictures of his through hulls.
        TexasAg01 - Paul
        '00 SANTE 210 - Current
        '89 Supra Conbrio
        '85 Glastron
        • bchesley
          • Feb 2006
          • 1252
          • Tyler, Texas
          Texasag01,
          The ones that skiking used were exactly like mine and Buckalgonquin is the supplier to correct craft. I used their valves too.
          2001 Super Air Nautique
          Python Powered
          100 Amp Alternator
          Dual Batteries
          Many upgrades coming...
          • bchesley
            • Feb 2006
            • 1252
            • Tyler, Texas
            Wakeslayer,
            Mine are the flat ones.....
            Python Powered
            100 Amp Alternator
            Dual Batteries
            • TexasAg01
              • Mar 2009
              • 36
              • Dallas, TX
              • 2000 SANTE
              #21
              Finished Product
              Guys,
              Thanks again for each of your help. Just wanted to follow up with my ballast install. Everything is now in and works great. I’m running factory tanks with 350 lb Fly High V-drive sacks mounted on top of the tanks. I then have a 400 lb bag in the center locker. I’ve left the aerator pumps in the boat to fill the center locker bag but plumbed in 2 new Johnson Ultra Ballast pumps for the rear tanks and sacks. I’ve attached pictures as well as my purchase list below. The guys at WakeMakers were A LOT of help. By the way, the Johnson pumps fill things up REALLY quickly. I took it out yesterday and I can have everything full in about 3-4 minutes.
              Purchase List:
              350lb Fly High V-drive sacks
              Johnson Ultra Ballast Reversible Pump (2)
              Ballast Rocker Switch (2)
              ¾” Bronze Thru Hull Intake (2)
              ¾” Bronze Ball Valve (2)
              ¾” Thread > 1” Hose Barb Fitting (2)
              1” Ballast Hose Black (20ft)
              ¾” Ballast Hose Black (20ft)
              1” Stainless Steel Hose Clamp (16)
              Fly High ¾ Flow-Rite Quick Release Connect (4)
              Fly High ¾” Elbow Flow-Rite Quick Release Connector (4)
              Blue Seas Systems ST Blade Fuse Block 6 Circuit w/ Ground
              Ancor Marine 10 Gauge Duplex Wire
              Also went ahead and replaced the battery switch on the boat with a Perko.
              TexasAg01 - Paul
              '89 Supra Conbrio
              '85 Glastron
              • TexasAg01
                • Mar 2009
                • 36
                • Dallas, TX
                • 2000 SANTE
                #22
                Pictures
                Inlets - exterior and interior
ID:	359926Click image for larger version
ID:	359927Click image for larger version
ID:	359928Click image for larger version
                TexasAg01 - Paul
                '89 Supra Conbrio
                '85 Glastron
                • TexasAg01
                  • Mar 2009
                  • 36
                  • Dallas, TX
                  • 2000 SANTE
                  #23
                  Pictures 2
                  Pumps - I attached these to the aluminum supports using 8"x5" custom cut aluminum brackets. I purchased them at a local machine shop for $16 and used stainless steel mounting hardware.
ID:	359930Click image for larger version
ID:	359931Click image for larger version
                  TexasAg01 - Paul
                  '89 Supra Conbrio
                  '85 Glastron
                  • TexasAg01
                    • Mar 2009
                    • 36
                    • Dallas, TX
                    • 2000 SANTE
                    #24
                    Pictures 3
                    I'll have to get some final pictures for y'all after I put the tanks in and laid the bags on top. I placed the perko and switches/fuse box for the pumps on the starboard side near the rear speaker. I didn't want to cut into the dash so this was the perfect place for me to put them. They're still easy to reach from the drivers seat if you need to level the wake while in motion.
                    Again, thanks for all of your help.
                    PH
ID:	359933Click image for larger version
Name:	Perko Switch.jpg
ID:	359934Click image for larger version
                    TexasAg01 - Paul
                    '89 Supra Conbrio
                    '85 Glastron
