Quick ballast question
  • mevirga
    • Feb 2010
    • 36
    • Santa Cruz, CA
    Hello-
    I'm installing a supplemental and independent ballast system that draws from the raw water intake on my '99 Air. It will fill/drain via a reversing puppy pump plumbed to 2 bags. I will TEE a vent line from each bag into the bilge pump lines. Question: do I need check valves on the vent lines?
    Thanks for the help.
    Mike
    • Jul 2026
    I would be more worried that your sac overflow would fill your bilge. I would think you would need check valves on both the bilge line and the vent, unless you have them oriented where down is always out.
    • mevirga
      • Feb 2010
      • 36
      • Santa Cruz, CA
      Yes. Thanks Chexi. You helped me answer my own question.
