How do you know the "True" oil level?
  • ponycar
    • Jul 2009
    • 52
    • Dallas, TX
    • 2005 196
    I changed my oil the other day in my 05' 196 EXC 330 and I was able to get just about all 5 qts of oil out, which I replaced with Rotella 15w-40 oil (5qts). My issue is that everytime I pull the dipstick it reads as if there were hardly any oil in the system. I haven't run the motor except for when I had to suck up 5 gallons of antifreeze, so I would suspect all oil is still contained in the system. Do any others out there have this issue and how do you get comfort with your oil level readings?
    05' 196
  • AirTool
    • Sep 2007
    • 4049
    • Katy, Texas
    RE: How do you know the "True" oil level?
    Don't be offended by this question.
    But are you sure you are correctly seeing the level on the dipstick? When I change my oil, I have a hard time seeing the clean oil on the stick until it starts to blacken. I usually have to pull it out quickly and then lay it across a clean, dry paper towel. The stain on the towel matches up with almost full.
    • j2nh
      • Dec 2003
      • 628
      • Spread Eagle Wisconsin
      Re: How do you know the "True" oil level?
      For me the comfort comes from measuring what I take out. Agree with Airtool, fresh oil is tough to read on the dipstick. On the EXC 330 it seems that the dipstick takes a convoluted path and you may be losing the measurement as you withdraw it. Is the boat level?
      Since you have above average intelligence, as demonstrated by your ownership of a 196, I have no doubt that the first thing you do after putting the boat in the water in the spring will be to warm it up, check for leaks on oil, fuel and water lines, and check the oil. No worries.
      2018 200 Team H6
      2009 196 Team ZR 409
      2005 196 Limited ZR 375
      2003 196 Limited Excalibur
      1999 196 Masters Edition
      1987 ProStar 190
      • ponycar
        • Jul 2009
        • 52
        • Dallas, TX
        • 2005 196
        RE: Re: How do you know the "True" oil level?
        Thanks for the comments. I'll give your paper towel method a shot combined. I just figured the boat would be just as easy to ready as my Tahoe and Honda, then again this may be a result of the convoluted path j2nh mentioned.
        05' 196
        • JUST-IN-TIME
          • Sep 2007
          • 293
          • ON YOUR BOAT
          always check oil when boat is on water and not on trailer
          if you check oil level on trailer try to get the boat as close as floating in water level
          i have seen too many screw ups on this
          HUMAN BUILT = HUMAN FIXED
          switchbait.com
          • core-rider
            • Feb 2004
            • 1364
            • Huntsville, AL
            • 2003 Black SANTE
            Re: RE: Re: How do you know the "True" oil level?
            Agreed, you will get the most accurate reading with the boat at rest while floating in the water. If that is not an option get the boat to sit as close to floating position as possible while on the trailer, then check the fluid levels.
            Jason
            All black 2003 SANTE
            -- Southern Fried --
            • AirTool
              • Sep 2007
              • 4049
              • Katy, Texas
              I changed my oil the other day .....My issue is that everytime I pull the dipstick it reads as if there were hardly any oil in the system.
              I don't think being on the trailer or not will cause the dipstick to read "as if there were harrdly any oil in the system."
