I have a conundrum. I have a 2005 SAN with 400 hours, just had it in for service and am being told the high pressure fuel pump inside the FCC is severely corroded and in danger of failing. The warranty just expired a couple months ago. This boat has always been used on a private fresh water lake, stored on a lift with a full tank of fuel, always used high quality name brand fuel from busy stations.
Maintenance always performed at suggested intervals. The only thing I can think is the crappy Ethanol fuel that the government is forcing us to use - is causing moisture to condense on the pump. PCM's statement is that the standard ethanol is ok to use. I am going to call PCM and see if they will warranty this. Any ideas?? Thanks!
Mike
Mike
