Another winterization question that seeks clarification.
My 98 owner's manual is not as good as others. So I here I am looking at the 2001. The winterization procedures that I am looking at states that you "remove the block feed hose from the connection on the raw water supply pump"......then you elevate this hose up to poor the antifreeze into the block.
It appears that my water route goes through the v-drive before it returns to the thermostate housing. Could I remove the line from my v-drive, use a short hose to poor the anti-freeze into the block?
If I drained the lines to the v-drive, added some antifreeze to them, hook-up everything back to normal, I assume I could then stick the inlet to the stainer into a bucket of antifreeze, fire the motor up and watch the anti-freeze emerge from the exhaust, I would then be winterized in terms of the cooling system.
And yes, I would pull the plugs to drain the water before as first step to the above, so no dulition would take place.
