I am looking at adding a air/wter temp gauge on my 99 san. Any thoughts???
RE: air/water temp...want to add
It used to be pretty easy to find a combination air/water temp gauge, with a depth sounder. But since they started having the factory incorporate those functions into the newer boats, the market for add on gauges went away, and gauge companies quit making them. you might still be able to find them, but it is way more difficult.
yep, i was looking for the stock-looking gauge. None to be found i guess. I did see the Faria in think-deep sounder with water temp...just a bit pricey.78 CC Amer skier(25yrs)
>>99 SAN gt40<<
The Faria one is pretty nice and I will be adding it this winter. The only downside is it has a chrome trim ring and I have black rings on my factory gauges. At least you can get it with a black or white face. There are no other options that will be close to fitting in your dash.2001 Super Air Nautique
Python Powered
100 Amp Alternator
Dual Batteries
Many upgrades coming...
If you have perfect pass you have water temp built in. For airtemp I think I would judt use a thermometer in the side pocket.Nautiqueless in San Diego
I'll probably get that Faria gauge. I would like Perfect Pass, but that will have to come later78 CC Amer skier(25yrs)
>>99 SAN gt40<<
