I noticed a small leak around the 4 bolts in the rudder plate in my 2002 super air, so I decided to clean and reseal the holes and plate with 5200. To drop the plate down an inch or so, I removed the pittman arm from the rudder. From what posts I have read, the rudder should move freely and just about fall out with the arm removed.
In my case, the rudder was extremely tight. I am not sure if I needed to remove the packing nut, but decided against it because I did not want to repack. I only dropped the rudder down about an inch to allow access to the sealant under the boat.
Should the rudder move freely with even with the packing nut still on? I have noticed the the overall steering is somewhat tight, and purchased a new steering cable for a future project. Also, what solvent has anyone found to work best for cleaning the old sealant off?
Thanks
Thanks
