Can someone post a link to one of the ballast install posts. When I use the search function it spits out thousands of posts most of which are irrelevant. I plan on replacing the hard tanks in my '03 210 with 750s. Thanks.
RE: Ballast Install
Funny...when I type in "ballast install" it comes back with 106 threads, most of which seem very relative. Seriously, there's lot's of good threads on this topic.....do a search and sit back and read, you'll learn a lot!2001 Air Nautique
RE: Ballast Install
You can search by original poster and I was one of them. Just search for ballast and add my name as the poster. That should pull up my 1998 super sport ballast install.2001 Super Air Nautique
Python Powered
100 Amp Alternator
Dual Batteries
Many upgrades coming...
Re: RE: Ballast Install
Not sure what you mean by the "storage shelf". If you remove the hard tanks then you should be able to fill up the sacs completely (based on the measurements from Fly High).Originally posted by mbaughJust a quick question, w/o searching through the existing threads. If you replace the hard tanks with 750s, can you fill them all the way with the storage shelf still in place?2003 SAN (current)
2003 Chaparral 220 SSi (sold)
