I was finally able to pick up an 02 Air Nautique SE with 195 hours on it. After taking it out several times I have noticed that the port side ballast tank will not fill all the way. It will fill about half way and then noticed that it was coming out of the drain or vent (dont know) hole from the hull.
This system has two fill pumps on each side of the motor and two manual valves right before the fill pumps. I have searched on this but seems that this may be a fairly unique setup to some of the previous Air and Pro Air versions. I do not have the white knobs under the LCS key pad (no key pad or whatever you want to refer to it as). I have a single rocker switch in the dash which operates both pumps.
Is there another vent valve on this setup that I am not turning on? Thoughts?
