I have a new to me ’05 211 team and can not figure out the ballast tanks either something isn’t working right or it’s owner error. The starboard tank will read full I will open the valve and hit the Starboard ballast button about 75% of the time it just lights up but is discharging water (maybe it’s just recycling) the other 25% it blinks (which what I want I believe) and really is discharging water. Once the water begins to die out I close the valve. I will run the boat for awhile and notice that the tank has refilled. The two sentences in the manual would lead you to believe that with the valve open it should blink and discharge every time. I now have the same thing happening on my port ballast. Should I have any water enter the tanks in the closed position? Likewise in the open position then hitting the ballast button should it blink and empty every time? Any differences if the boats in AUX/Ready mode vs actually running other than you can’t monitor the gauges if not fully running.
Any ideas help is very much appreciated. Thanks folks
ETC
ETC
