So we replaced the hard tanks in my buddies 05 SAN with the 750 pro-x sacs. All of the pumps are aerator style pumps. The problem is when we fill them the water pushes by the drain pump and starts draining the sacs without the pump running. The pump is on the bottom fitting of the sac which is the only place I think it could go. If it is on top I think it would pull air when draining, plus I don't know if the fill could handle filling the sac from the bottom fitting.
My thought is a longer piece of hose that loops up higher not allowing the water to flow out.
Any other ideas from people that have done this and made it work??
