I have a 95 super sport and 3 weeks ago I put in a second battery and a perko switch. I checked the voltage and it metered okay. When I put it in the water and starting driving I noticed the voltage meter spiked and the perfect pass reset itself so then I shut the engine off and it wouldn't start because there was no power.
I figured out that the 60 amp breaker had tripped so I waited for it to cool and reset it then I tried different settings on the perko switch (battery 1, both, battery2) and every time after about a minute of running the breaker would trip. So I pulled the boat in and left it overnight.
The next day I took out the switch and went back to just running off of one battery. Everything worked and it was fine for a week.
Took it to my mechanic to check things out and he replaced all the spark plugs and the distributer cap (which was pretty corroded I guess) and said it was running good.
Took it out on the lake last night and after about half an hour the breaker trips. I switch batteries and disconnect the amp for the stereo and power to ballast pumps. The boat runs for another 15 minutes and the breaker trips again so I pulled the boat out and here I am.
Sorry about the long story
