I've put 25 hours on her this year with no problems. Winterized at the dealer and tuned up about 50 hours ago. We ran the boat for 3-4 hours, surfing and wakeboarding loaded up with people and ballast. After a lunch break of about 2-3 hours we hooked up 2, 2 person tubes with 4 10 year old girls in them, no ballast and about 5 adults in the boat. I idled out from shore fine, about 300 yards off shore I gave enough throttle to try get up on plane. It only took a few seconds to feel the first sputter, then about 10-15 seconds later the engine died. Would only restart for a second or two then die. We paddled back to shore and started trouble shooting. We were beach camping so the boat was floating anchored the whole time.
Having never worked on the fuel system in my boat, we started from scratch.
Lots of gas in the tank, gauge read 1/3 tank.
Cut off switch seems to still work same as always.
Engine hours and guages still work on dash.
*When we removed the FCC it was empty, only about 1/4 inch of fluid in bottom, at the time I didn't know the filter is in the bottom of the FCC, so we didn't check it. Since the FCC was empty, I'm pretty sure the HP pump is working. The O ring that seels the FCC broke when I removed it. So I had to rig some electrical tape. Could a broken O ring have been the problem
We took apart the LP fuel pump, the C shaped screen filter did have some stuff built up. We cleaned it.
*We filled the FCC with fuel to prime the system. It started and ran perfect.
The next day we surfed and wakeboarded for 2 hours straight, stopping and starting the engine. Even a couple of beginner wakeboarders who couldn't get up after quite a few tries. So a lot of starting and stopping and pulling.
*We loaded the boat with camping gear and some friends to take them back to the dock, almost identical to the tubing issue. We idled about 300 yards off shore, as soon as I gave it some throttle and it sputtered a few times, and died again.
Any ideas?
Any ideas?
