Greetings-2 items that I need some help with. My check engine light started coming on when we were using it today...temp good, oil pressure good...other ideas? Other issue, which may be related..when I checked my oil level today, I noticed that it was a bit milky white on the dip stick. After running it for a few minutes, it look normal. I have used it a 12+ times this year, checking the oil every time and it has appeared normal color. Water in oil??? and from where?? I have a 1999 Air Nautique.
Any help would be GREATLY appreciated!!
