On the maiden voyage this year my 86 sn2001 had an unusual problem. It starts fine, but when in gear it will not go over 1000 rpms. It just bogs. In neutral it will rev fine. I had a similar problem 3 years ago but with a 3000 rpm limit. That was just some moisture under the distributor cap. The cap is dry now. The throttle linkage also checks out okay.
Last summer I replace the cap, rotor, and wires. And it was running fine before I put it up for the winter.
Any suggestions would be appreciated.
