I winterized my boat for the first time and I found that the plugs were all striped pretty bad. Now it is time to put the plugs back in and I can run a tap through the block plugs pretty easy but the plugs from the manifold are in pretty bad shape and may need to be taped a bigger size. Has anyone done this or have any tips. I did not have any leaks in the system last year but I figured that this is the time to fix it.
Thanks, Nick
Thanks, Nick
