Hope someone can help with this. It seems to have started after start up last year. Launched the boat (99 Air Nautique) and was driven about 1/2 mile, the fresh water impellor failed and clogged the coolant lines to the manifolds. It melted the pass. side 4" exhaust. Now it will start and run fine, couple passes around the lake, sit at the sand bar for a bit, take off, and within seconds it dies. Sit for a half hour or so it wil start up and run. My first guess was Ignition moduel but no. After taking some tools out and getting it to do it again we found no fuel pressure. Both the high and low pumps get initial key on voltage when it doesn't run. when removing fuel lines I found little or no gas in the output of the low press. pump. I tore into the supply line line, tank connection etc everything seems to be okay. Hoping that maybe the supply line was damaged in the exh blowout I replaced that when winterizing but have not had it out yet. Again,it will start right up and run, you can ski no problem, just sit for a bit and when you go again it dies until something cools down My first thought is to put a new low press pump un and try that. My thinking is there is only the high and low side pumps left???
Thanks for any help guys!! want to ski this long weekend!
Randy
Randy
