Battery connected backwards and now no power anywhere
  • Rdavis914
    • Apr 2009
    • 9
    I have a 95 Sport Nautique with a carburated 351 and today when I got the boat in the water the battery was not strong enough to turn the engine over. I think something was accidently left on but I borrowed a battery from someone at the ramp to try and start the boat but accidently connected the leads backwards. I know not the best or smartest thing I could have done but now i'm not reading anything up front. Where could my problem be? What might I have damaged by doing this?
    I checked the breaker in the engine compartment and it appeared to be in. Is there another breaker or fuse box that i'm not aware of the could have tripped?
    Thanks in advance.
  • jward
    • Feb 2008
    • 620
    • Sweet Home Alabama
    • 03 SANTE 04 SANTE
    RE: Battery connected backwards and now no power anywhere
    There is a large bus fuse on the red battery cable next to the starter on most boats not sure about yours. Should be though. I popped one before after doing the same thing.
    • Rdavis914
      • Apr 2009
      • 9
      I traced the battery cable back and it went from the battery to the 60 amp breaker on the back of the engine through the starting relay and then ends at the starter. I didn't see any additional fuses.
      • bchesley
        • Feb 2006
        • 1252
        • Tyler, Texas
        Jward his is a carb boat. I will not have the big fuse. You are going to have to start at square one. Get your voltmeter out and start tracing the wires to find where your current stops. If you have 12 volts at your battery, go to the end of the cable and see if you have it there. If you have 12 volts at the relay then move forward and so on. Something got fried you are just going to have to find it. Happy hunting!!
        2001 Super Air Nautique
        Python Powered
        100 Amp Alternator
        Dual Batteries
        Many upgrades coming...
        • Rdavis914
          • Apr 2009
          • 9
          That's what I was affraid the answer was. I was hoping someone had gone through this before and could point me to the path of least resistance.
          • Hollywood
            • Sep 2003
            • 1930
            • WIIL
            Re: RE: Battery connected backwards and now no power anywher
            Start here.
            Are you sure the breaker is in? Did you push it or just look at it?
            So, after you installed the cables wrong, then what did you do? What batter is in it now and where did it come from?
            • ffmedic74
              • 835
              • Lexington, KY
              RE: Re: RE: Battery connected backwards and now no power any
              Once you find your issue, sounds like it might be a good time to put in a 60amp breaker after the battery so it doesnt happen again in the future.
              • Hollywood
                • Sep 2003
                • 1930
                • WIIL
                • Rdavis914
                  • Apr 2009
                  • 9
                  I pushed on the 60 amp breaker and it didn't move so I assumed that it was not popped. Is there any way to pop it and reset it manually?
                  After I connected it backwards I tried connected it correctly and I get no battery indication at the on the instrument panel. There is no battery in it now but I have trickle charged it overnight and I am going to put the original battery back in.
                  • Rdavis914
                    • Apr 2009
                    • 9
                    I reconnected the battery and read out the power and followed it until I didn't have power. I have power going into the 60 amp breaker but not out of the other side. I jumpered that contact out from the starter solenoid and I then had power to the dash and starter.
                    I have tried pushing the breaker and it won't move at all. I'm thinking it's probably old and won't actually pop but is probably disconnected internally. I'm probably better off replacing it anyway.
                    Anyone have a part number for this breaker? Can I get it at any marine supply or should I go through White Lake or the local Nautique dealer for a new one?
                    • jward
                      • Feb 2008
                      • 620
                      • 03 SANTE 04 SANTE
                      Glad you found your problem. Bet you won't do that again.
