Hi,
Sorry if this appears twiice. It really looked like it didn't take the first time.
Hello everybody,
I am very glad to have found you as I need help. Sorry if this gets drawn out but there is a fair bit of detail needed to explain. Firstly I live in Australia and not close to a major city either. The only PCM dealer in this country is 3000 kms away and doesn't specialize in Nautique or PCM for that matter so basically we are on our own except for what we can find in the manuals and by the internet.
We bought a 2004 196 ski with a ZR6 in it about 2 years ago. It was an ex club boat used for one and a half seasons on a salt water site and had about 700 hrs on it. Nautiques are rare over here but I spent a few years in the states back in the 90s and fell in love with them so when this came along we checked it out and jumped in. It really was kept in good condition and well serviced. Being a saltwater boat is not ideal but then again the ZR6 is freshwater cooled.
Anywho thats a bit of history. We did services ourselves ; as you all know the basics of oil, filters ,belts and water pumps is pretty straight forward. That is until it goes wrong. Complacency was our mistake and it was a big one. We had just done a basic oil and filter. We went back in the water, warmed the boat up and got into the first set without checking under the hatch. We had a major filter failure and dumped the whole 5 liters of oil in the engine bay. Obviously we freaked, shut it straight down and went about the process of cleaning up and checking for damage. To cut a long story abit shorter the simple result was total destruction. A warm up and 3 passes at 34mph and it was finished. I couldn,t believe it. What happened to an alarm of some kind or shutting down to limp mode. I have learnt alot more about its protections after the fact than I knew before, another mistake of ours. I just didn't think it could happen.
Anyway continuing on. We had done some reading previously and thought the single beep from the perfect pass module was actually the alarm self test indicator. We now know it is actually 2 beeps. The check engine light had never lit before either. So we are now thinking, well salt water boat , maybe we had sensor failures and didn't realise due to salt etc. Maybe engine management system has an error. Its all a bit arbitary now anyway.
Well grab a hold of your balls coz things are more expensive over here than for you guys. $13.5 K and 1.5k for fitting later we have a brand new 2008 343 Excalibur. We went for the ex 343 coz the ZR6 was $17.5 K and we couldnt afford it. That was one expensive oil change and it still keeps me up a night sometimes. Gotta let it go and move on.
Now for my real issue. I was really hoping with the entire new engine, when we fired it up, we would now finally get a real self test 2 beeps and check engine light. Nothing
Firstly can someone please tell me. Even if it takes a while to get to the bottom of these indicators, surely the engine will go into limp and reduce RPM if we have some other type of failure. Mind you I guarenttee we will never see 5 litres of oil in the bottom of this boat ever again but I want this thing working right. Surely it will protect itself?
We have used a PCM adaptor plug to connect the existing CC wiring and everything else works fine just a minor alteration with the fuel pump and we are on line. So now I'm thinking the problem must be under the dash. I have pulled it out and can not find any audible device except for the one attached to the perfect pass. Is it housed in the tacho or speedo? Is it maybe not there? The check engine light is obvious to see and the wiring looks fine. I think I will just replace it. Can someone please explain how the alarm system works and where I can find the major elements to it? I am a sparkie and I am pretty determined to nut it out and make sure this never happens again.
Well if your still with me thanks for listening to the sob story. I would really appreciate any help in getting to the bottom of this.
Happy Skiing.
Thanks CoopsinOz
Hello everybody,
Happy Skiing.
Thanks CoopsinOz
