Ok, my lake temp sensor which shows in the lcd of the tach on my 05 limited is about 10-12 degrees off, so I need to look into that. On the limited's, where is it? I'm not finding anything that looks like it at the hull or engine area. Thanks.
RE: Where is lake temp sensor on limited?
Check the raw water intake line - it should be located between the shutoff valve near the through-hull fitting and the strainer.
I saw that. It's not a conventional sensor there, but a big T in the line with a compression fitting and 1/4 hose going somewhere. Hmmmm. I wonder if it goes back to the black box where the pitot's connect too.Shane Hill
2014 Team 200OB
67 '13 Prophecy
