As soon as the engine starts, the huge red warning light in the center of the dash comes on -- in the manual it says this is an early warning indicator for either high temperature (water???) or low oil pressure (gee, that's a big help correct craft) -- This light is impossible to see in bright sun light making it pretty useless :evil: , I ran the boat for at least 30 minutes with it on...however, both water temp and oil pressure guages appear to be reading acceptable levels -- oil pressure is 40psi at idle (doesn't move much with higher revs) and water temp is not over 140 when warmed up...
However, since the warning light comes on immediately even when the engine is cold, I wonder if it could be due to low tranny oil level (appears to be down a quart) ..
The engine has about 220 total hours on it and is the PCM Engine Model PLL TBI 5.7L 275Hp (I've been told its a GM ) anybody know where I could get a more detailed manual online?
...I'd also like to know how to check the tranny filter screen...the last time this engine was serviced ... the knuckleheads left the fliter screen out of the sherwood in-line filter so that may or may not have contributed to what the problem is.
Does anybody know exactly what that "idiot" light measures and where the sensors are located??? THat's probably the biggest question I have!
I've pulled all the sensor leads I could find and none turn it off...disconnected the battery too...I can only find an oil sending sensor near the oil filter but no oil switch...is there one? Would a tranny pressure switch feed it too? I would imagine that the water temp switch and the oil pressure switches are what "feeds" this idiot light but I can't find any others to track...a bad ground could also be the problem but saw nothing obvious...HELP!
Thanks for any help you can give...great forums...John.`
