What the **** have SANTE 210....its in the middle of oil change cycle about 20hrs left...out bordin oil hg ligt flashing!!!!check oil none on stick!.....last change added factoruy reccommended amnt....plus extra per engin needs...used rerccommended heavy duty rotella...dont seee any ss (sorry im a nurse: signs and symptoms) of a leak ie. oil in engine compartment....should i have to add oil this soon....Im pretty knowledgable about car engins....does a boat burn oil due to torque....is my new fin boat a pios....im pretty pissed offf @ this point....im adding oil about every couple of months ...IS THIS NORMAL?
RE: 07 SANTE...Oil Useage!
The engine probably didn't get broken in properly. You need to check the plugs and see if they are fouling.
Your oil ring didn't seat properly. Best thing to do at this point might be to do the throttle up and coast trick as often as you can. After a few hours, check or change your plugs and hope that your valves don't foul.
There is also a chance you have a leaky valve guide seal and your smoke is at restarts only. This is an easy fix (relative).
I suggest a dry and wet compression test to check your rings.
AirTool
it is under warranty---let CC deal with it2001 SUPER AIR (current)
2002 BAJA 25 OUTLAW (current)
1995 SKI NAUTIQUE
2018 NAUTIQUE G23 (gone)
2006 COBALT 24 (gone)
2003 LIBERATOR 21 (gone)
2016 SANTE 210 (gone)
2012 SANTE 210 (gone)
2008 SANTE 220 (gone)
2004 SANTE 210 (gone)
1998 BAJA 252(gone)
1998 MALUBU WAKESETTER LX(gone)
2000 CARLSON (gone)
1992 MC MARISTAR 240 (gone)
1994 GLASTRON 175 (gone)
boats can use 1quart of oil per 10-15hrs
HUMAN BUILT = HUMAN FIXED
switchbait.com
They did that to keep the compression ring lubricated.Originally posted by jpskiSome chevy's just plain burn a little bit of oil. How many hours are you going between oil changes?
Yeah....if it's a 2 stroke.Originally posted by JUST-IN-TIMEboats can use 1quart of oil per 10-15hrs
Otherwise the oil ring didn't seat.
air tool
some engines can burn 1 quart of oil evry 10-15 hrs of use at WOT
was in our merc notes from school
switchbait.com
My 08 210 seems to like to burn oil too. I had to add a quart before I made it to 25 hours, and I was following the burn-in procedures to the letter. When I took it to the dealer for the 25 hour service, they said that that was normal and not to worry about it. During normal usage at approx. 70 hours, my check engine light came on and when I checked the oil, I was about two quarts low. Once again, the dealer told me this was normal behavior. I too have been using the Rotella oil just like the manual states. The boat runs fine, all the guages show fine, and the oil pressure reads fine. I'm just assuming that this is normal since the dealer is telling me that it is.
Chad
Every engine uses some oil. If you think your engine does not "use" any oil, rest assured that the oil that is being used, is being replaced by combustion by products that are keeping the apparent oil level about the same.
Do you see blue smoke when you accelerate hard? That would worry me more.
My manual says to check the oil level before each use.
You should also drive the engine at WOT when breaking it in. Do not hold WOT long, just long enough to reach max RPM, and then close the thottle to idle, until the boat slows down to no wake speeds. Do this cycle a lot.
I did this with my 1997 Ski, it now has 2055.3 hours and runs good, and at the last oil change, got out about 4 quarts of oil after running the engine about 50 hours.
THANKS EVERYONE!
after several late model nautie owners had the same issue an inquirty was launched in conjunction with PCM...in summary: IT WAS MY **** KIDS FAULT!!!!! No more extreme tubeing for the belle family....the loads of pulling the tube through the massive swells created by my 210 + TX 100 deg heat+power prop=strait 40wt BINGO problem fixed...I LOVE NAUTIQUE, PCM and BUXTON MARINE!Life is Short/Ride HARD! >>> 07/08 SANTE 210
