Fuel Control Cell / Fuel Pump
  • nch20skier
    • Feb 2004
    • 167
    • North Carolina
    After having the boat let me down at SML last week-end I have arrived home, fixed the issue and have confirmed all is ok.
    It appears that the fuel hose from the high pressure pump was the culprit however I went ahead and changed the pump just to be sure.
    Everyone should take note of this post and others and take the time this off-season (is there such a thing?) and remove the FCC and replace the filter and hose from the pump to the FCC. It seems as though the 96-97 PCM engines had a vinyl hose that was not suitable for gasoline and will fail (in my case at the most in opertune time).
    To remove the FCC can be a struggle in itself. I ended up with a strap wrench and 2 rubber grip pads from the kitchen along with a 2' section of pipe for additional leverage.
    88 Barefoot Nautique
    05 206 Team
  • SoCalNautique
    • Aug 2006
    • 22
    • Ontario, CA 91761
    Thanks for the heads up.
    I have a 97 SNOB and only only it for 3 years. I don't know if the p/o ever changed the filter or hose but I have not. Any of you guys out there recommend changing the filter/hose anyways..just to be safe?
    • shag
      • 2217
      Probably a victim of ethanol.... Just my opinion.
      • jerriojr
        • Aug 2010
        • 1
        • '96 SS
        jerriojr
        Were you having any starting or throttle problems prior to your discovery?
        • toddrswenson
          • Aug 2004
          • 222
          • Pearland, TX
          • 97 Ski Nautique GT-40 LOVE IT
          I had the same exact thing happen. I have a 97 SN and the hose was clear. Talked to my dealer at the time and he pointed me in the right direction. I was about to change the pump. Instead it was a two dollar fix.
          2002 Air Nautique GT-40
          97 Ski Nautique GT-40--- Sold
          LOVED IT
            My 1997 Ski Nautique, (with 2280 hours) has the black hose on the high pressure fuel pump in side the FCC. I have not yet had a hose failure. Most of the boat's life, I have been running the E-10 gasoline alcohol mix.
            • ers906
              • Feb 2010
              • 921
              • Phoenix AZ
              Are these hoses you are talking about replace by the braided style in the 2002 etc SANs? I am all about preventative maintenance. I even check the PP servo in the driveway before going out. Just easier to fix something on dry land than try to do it on the fly. Plus, then I dont have to hear the gf whining about the radio going on and off as it turn the boat on and off.
              Eric, Phoenix AZ
              G23 550 hp (finally here)
              2002 Super Air
              • JayG80
                • Dec 2006
                • 215
                • Santa Fe, TX
                • 2007 Ski Nautique Sold 2002 Ski Nautique
                Same problem with my FCC on 2002 SN196. Braided black hose. I thought my issue was the anti-siphon valve at first but turns out there was a crack in the hose. I bought a foot of hose to keep as spare in my tool box. In the future I'll change it every time I change the filter.
                One day I noticed that boat need a lot more throttle while skiing. Throttle went from 9:00 position down to 7:00. Then during the ski set it got worse. Next was poor idle and then backfire.
                • JBird97Nautique
                  • Nov 2023
                  • 93
                  • FL
                  • 1997 Nautique
                  I see this part on NP SLsite but wondering where I can get locally and what size?
