This is a diagram of the relay connections used on the "Bosch" type relay commonly used on cars, boats, ETC.
Pin 30 normally goes to a power source, through a fuse or circuit breaker.
Pin 87 normally goes to a load of some type. (lights, fuel pumps, engine computers, whatever. Pin 87 connects to pin 30 when power is applied to pin 86, and pin 85 is grounded.
Pin 87A connects to pin 30 when the relay does not have any power applied to the coil
Pin 86 is the coil positive side.
Pin 85 is the coil negitive side.
A lot of times, pin 30 is always hot, even when the key is off, or in the case of my boat, even with all the breakers off.
The coil of these relays is switched on or off on either the "ground" side, or the "hot" side.
Example: on a GT-40 engine in my boat the key applies power to pin 86 of the engine computer relay, and pin 85 is grounded. The key switch controls this relay.
When the engine computer relay is turned on, power is applied to pin 86 of the fuel pump relay, and the computer only grounds pin 85 wnen the computer thinks the fuel pumps should run. The computer switches the ground side of the relay.
