I have a 2002 super air and my speedo and tach went out. I was told this was common with the 02 boats. I was also told correct craft had a recall on these and to call and see if the recall has been done on this boat. I am not the original owner so I am not sure what has been done to this boat. Any help would be great. Thanks
Hi,
If you have green digital gauges they are probably the faulty teleflex gauges you will find tons of posts on if you search...
One question though, are they completely dead, or is the read out just flaky, as in not readable, if its the former then you could have a different issue.
jmo2018 Ski Nautique 200 TE, H6
I had the same issue on my 02 Supersport. I called Teleflex and they sent out a new analog speedo to replace the digital. They will not send another digital to replace it. The other issue was that the bezel did not match the rest of the gauges. I recently put PP on my boat and removed the analog speedo along with all the pickups for the speedo system. If you need to fill the hole where the speedo is currently, CC has a blank that will fill that hole in your dash. I still have the digital tach, and it seems to be holding up but odds are I will be replacing that someday also!!!
fyi, I have a brand new speedo and tach set that matches the 2002 Nautiques. The retail price (if you could still get them) is like $450+ for both of them. If anyone is interested, make me an offer.2001 Pro Air Nautique
how much?Originally posted by cycle669I had the same issue on my 02 Supersport. I called Teleflex and they sent out a new analog speedo to replace the digital. They will not send another digital to replace it. The other issue was that the bezel did not match the rest of the gauges. I recently put PP on my boat and removed the analog speedo along with all the pickups for the speedo system. If you need to fill the hole where the speedo is currently, CC has a blank that will fill that hole in your dash. I still have the digital tach, and it seems to be holding up but odds are I will be replacing that someday also!!!
I know I'm by far in the minority when it comes to the digital gauges, but I'd be interested in this option to get them repaired, especially if tach hours will not be reset. My gauges are finally starting to get a tad flakey, and I really don't like the look of the replacement analog Faria's. The digital gauges are a unique feature of my era boat I'd like to keep, so if you have any further information on their repair please pass it along.
Anyone else had this repair done?'08 Super Air Nautique 210
has anyone sent their gauges out to be repaired? and if so where to?Ryan
2001 Super Air Nautique 210
