1 very loud pop in engine bay during holeshot or pulling ski
  • schiffsnautique
    • Mar 2007
    • 57
    • Up the Allegheny from Pittsburgh
    • 98 Natiuque Super Sport 93 SNCB
    i have 93 closed bow with 420 hrs. i've had it for a year and has ran great. yesterday i heard a loud pop like metal being broken during a holeshot. i checked the motor mounts nad didn't see anything wrong. later the driver heard it when i was getting out on a slalom so i quit. the boat did it once out of 5 times when i was wakeboarding. the faster and smoother i got out of the water everyting was fine. it also did it once in 4 times on a kneeboard. the pop wasn't heard when i eased into the throttle to cruise but i did notice some quick revving at cruising at 2800 rpm. rpm's would go up really quick then go back to the original throttle position. could the knock sensor be the culprit? also, i noticed that the oil dipstick had been forced out slightly and i know that i had placed the entire way back in. any insight would be grealty appreciated.
  • AuMDLST
    • Apr 2007
    • 870
    • Orlando, FL (Butler Chain)
    RE: 1 very loud pop in engine bay during holeshot or pulling
    Potential Backfire?
    2006 SANTE 210 (Pending Sale)
    2005 206 TE (Previous)
    • core-rider
      • Feb 2004
      • 1375
      • Huntsville, AL
      • 2003 Black SANTE
      Is this a carburated engine? If so, it was probably a backfire through the carb. It could happen with FI, but not nearly as possible. Might just need a little tuneup or carb tuning/rebuild.
      Jason
      All black 2003 SANTE
      -- Southern Fried --
      • schiffsnautique
        • Mar 2007
        • 57
        it is carburated. just thought of the fuel goin in under certain circumstances.. but why would their be a backfire only during more load to the engine and only once when pulling out or holeshots? and what about the rpm jumping from time-2-time when cruising?
        • schiffsnautique
          • Mar 2007
          • 57
          i had a 91 wellcraft i/o and heard it backfire a couple of times under a strong load. the wellcraft was easy to tell of a backfire. i've had a few street 5.0 mustangs that had motor work and have heard the same backfire like the wellcraft. the nautique was much more of a distinguished sound that i've never heard. i'm aware that the i/o is placed further back and their is not a muffler/silencer like my nautique. just tryin to give as much info as possible to find the cause.
          • 81nautique
            • Feb 2006
            • 257
            • Big Rock, Illinois
            • 2012 200 Sport 1956 Correct Craft Collegian Past boats 1955 Correct Craft Hurricane 81 Anniversary Nautique 1960 GlassCraft Ski Nautique #1
            power valve gone bad?
            • schiffsnautique
              • Mar 2007
              • 57
              not aware of a power valve???? what is it?? is this something with a carb 5.8 pro boss?
              • 81nautique
                • Feb 2006
                • 257
                Re: RE: 1 very loud pop in engine bay during holeshot or pul
                Power valve is inside the primary side of the carb. It increases fuel flow +-20% under demand based on engine vacuum, if it is blown the engine will lean out and cause a backfire. you might want to post this question over on CCfan. and let the Holley gurus at it. If it is the PV it's a less than $10 part and a new gasket set for the bowl and block, inexpensive fix or just buy a kit and have the carb rebuilt.
                • donjoz
                  • Jun 2008
                  • 4
                  RE: Re: RE: 1 very loud pop in engine bay during holeshot or
                  I had a similar problem with my old '92. It sas backfiring under load. Ran fine anywhere else.
                  The fix was not so easy. It could be lots of things, but mine was a bad coil pack. A very, very good mechanic diagnosed it step by step for me.
                  Good luck. Have a look at your electronic ignition and connections.
                  Don
                  • 81nautique
                    • Feb 2006
                    • 257
                    Re: RE: Re: RE: 1 very loud pop in engine bay during holesho
                    Don
                    Good call, Protec ignition on it's way out maybe
                    • schiffsnautique
                      • Mar 2007
                      • 57
                      RE: Re: RE: Re: RE: 1 very loud pop in engine bay during hol
                      thanks for the input. i was curious about the coil pack. talked to a friend that is an excellent mechanic and may have traced the problem to the number 6 plug. the ceramic had came loose. had the boat out last night and ran perfect. i think pro-tecs are good but had a car with a coil pack and wasn't very happy. hopefully the problem is cured. another question, i'm going to start using a set of old plugs during the fogging process and then put the good set back in after i've de-winterized it. i always put the fake-a lake on in the spring to check everything before launching. does anyone else do this. i believe that it offers some preventative maintainence. you guys?
