I just bought a 1997 Natique with the GT-40 engine. Currently it is not operational. I found a copy of the diagnostic service manual online and have been trying to troubleshoot the problem myself as the nearest dealer is ~3 hours away. I have spark, but the fuel pumps will not run. When I take the pumps off and put 12V to them, they work. With the leads to both fuel pumps disconnected, I get 12V to each for the first second or two, then I get about half that. However, when I connect the leads back to either pump, and then turn the key on and check for voltage on the leads to the other pump, I get nothing. My current thinking is that it may be something with either the fuel pump relay or the 15AMP circuit breaker that the power to the pumps passes through. I should mention that this started as an intermittent failure to start, then progressed to it dying on me at 25 mph. Any help is appreciated. As you might guess, it has been extremely frustrating to look at the boat in front of my house and not be able to use it. Not to mention blowing several weekend afternoons so far working on it. The summer is NE here is ticking away and I'm about ready to drive it up to NH for service but just figured I would take a stab at posting here and see if anyone had any ideas. Thanks.
- Bill
- Bill
