When I bought my 06 206, there were two aluminum poles in the boat. One was obviously the cover prop up pole to poke through the grommet in the cover to keep rain water from pooling.
The other pole is not so obvious to me. See pictures below. Note one end is missing the rubber plug.
What is it?
AirTool
What is it?
AirTool
not real sure what you got there but i would make into one of these. makes for fun times when the water is a litttle to ruff
or like it may be two pieces to be used with or without the filler cushion. It may be possible that your boat had that small cover and it was not given to you at purchase
