When I put on the anchor light or bow / anchor light mode, the backlights on the dash gauges do not light up. The ballast gauges light up properly... I know the dash gauges are part of the serial bus, but are the ballast gauges?
I called Correct Craft and they believe it is a problem with the gateway box (CPU) and that it would have to be replaced. The boat is still under warranty, but I regret having the gateway replaced again. Last time, I lost air and water temp option but gained depth finder at startup instead of having to menu to it... I'm concerned what I will get this time.
Also, I asked for a true service manual. None available...the only documentation is the interconnect diagrams that are on this website.
Any ideas?
2003 206 Air Limited
Any ideas?
