I have 1986 Ski Nautique 2001 with a Ford 351 engine. The engine misses badly when under a load (runs great when sitting in the driveway). It had the same problem last year and the following was done to try and fix it:
1) Took out points and put Pertronics HEI unit in
2) Replaced spark plugs
3) Replaced plug wires
4) Replaced distributor cap
5) Replaced ignition coil with one having an internal resister and bypassed the ballast resister.
6) Checked, cleaned, and put back in the Fuel/Water separator
7) Had carburetor rebuilt
8) Replaced distributor (which put it back to points).
After replacing the distributor the problem was fixed for about 10 engine hours, then it slowly began to miss again... and got worse and worse. I thought the fix was due to the new mechanical advance in the new distributor.... but not certain.
Last year, the engine would not rev up past about 3200 rpms. This year it will rev up to whatever, but misses and putters the whole time, when under a load.
Both the old and new distributors are Prestolite. As I said, on the old distributor I changed out the points to an HEI system and then back to the points trying to find the problem. The new distributor had to be points because the HEI adapter didn't fit with the new rotor and I had the same problem with all the different set ups.
On Monday night I ran the boat in the driveway. It was really tough to start but when I got it running I put the timing light on it, revved the engine and looked for it to cut out (timing light not flash when it should). It never did, and the engine sounded great! I started it up several times and checked all the cylinders with the timing light, but didn't see anything wrong and it ran nice... except that it was tough to start, until I disconnected the tachometer, then it fired up easy every time. (Is that just a coincidence or is there a reason that might have an effect?) So it didn't make a whole lot of sense to me, but thought maybe that had fixed it.
So, my buddy and I took the boat out to the lake Wednesday night for some more
diagnostics. We put the boat in the water and the first time we tried to take off (thus the engine being loaded by the prop in the water) the engine cut out and sputtered as it climbed up the rpms. (We were discouraged even though we figured beforehand it was probably not fixed) Next we put the timing light on and watched it as we took off. We did this for each cylinder and found that cylinders 1 and 2 never cut out, but cylinders 3-8 sporadically did cut out. As the engine would sputter we could see the steady flashing of the timing light miss a flash one time then miss 2 or 3 in a row others (this is our assumption since the 'cut out' appeared stronger sometimes then others). It was easy to see cylinders 3-8 cut out, and we tested cylinders 1 and 2 a lot but never saw them cut out. The firing order is 1-3-7-2-6-5-4-8 so the good cylinders are not next to each other on the distributor... thus I’m thinking the problem is not associated with the distributor... maybe...???
Any ideas?
Other notes: The HEI unit is Pertronics, but not currently utilized in the engine due to it not fitting the new distributor rotor (will put it back on ASAP, but have to manufacture an adapter to make it fit)... and again, I saw the same problem with the old distributor too with and without the HEI unit.
Thanks in advance… this problem has been plaguing me for over a year and I’m really frustrated!
Any ideas?
