Just had some gear replaced under my boat from a little mishap last fall.
I was wondering....
How easily should the prop turn on the shaft through the prop strut when out of water?Right now it does turn, not easily though, and sqeaks a bit as it turns in the prop strut. Is this normal?
I really wont have a chance to do a wet run with the boat for about another month.
PS> What I'm calling the prop strut is the bronze thingy that holds the drive shaft behind the prop.
I was wondering....
