Best surf setup G21
  • Trench
    • Feb 2018
    • 1
    • orange county
    • 2017 g21
    Best surf setup G21
    What's the best surf setup ?
    Sent from my SM-G955U using PLT Nautique mobile app
  • AcerMD
    • Mar 2013
    • 39
    • Calgary, AB
    Following.
    • F725
      • Feb 2013
      • 381
      • Minnesota
      • 2018 G21
      Here is what “we” like the best.
      Belly 15% if nobody in the bow
      starboard 75-80%
      port 100%
      speed 11.1-11.2
      NCRS 0-2 (rider preference )
      NSS 0-2 (rider preference )
      adjust ballast and settings slightly as needed to tweak the shape and length.
      We ger get a real nice wave on both sides with this set up. Tall, clean and long.
      • kodiak
        • Jan 2014
        • 157
        • Salt Lake City UT
        • 2021 G23 ZZ8 2014 G21 550.(Sold)
        https://www.youtube.com/watch?v=GnU23sa8ciY
        Not sure what he has Ncrs or Nss at? Not hard to figure that out with just testing the different settings.
        • F725
          • Feb 2013
          • 381
          • Minnesota
          • 2018 G21
          I got my Settings from Tommy. Being goofy, he probably put more weight on the starboard side instead of 75%
          • Slavoise
            • Jun 2019
            • 8
            • Lake Havasu (Boat)
            • 19 G21
            I run the following for regular:
            30 % Belly (Lower if people in bow)
            100 % Port
            80 % Star
            11.3 - 11.4
            NCRS 0 -1
            NSS 0-1
            This setup produces a really long wave with massive push.
            • Slavoise
              • Jun 2019
              • 8
              • 19 G21
              I forgot... I also run 150 lb lead in the observers area and 100 lbs in each rear pocket locker. I also have 100 lbs at the front of the compartment behind the drivers seat and in the opposite compartment on the port side.
              • plsweet
                • Mar 2020
                • 2
                • IL
                • 2020 G21
                I tried the settings on my 2020 G21 and it makes mush. I had to go 80% Belly, 100% Port, 80% Starboard, NSS 5, NCRS 4, 100 pounds lead in the Port Observers Locker. The surf wave is good. My 2017 Mastercraft XT23 put out a cleaner surf wave.
                • Daveinmammoth
                  • Apr 2017
                  • 2
                  • Mammoth Lakes
                  • 2014 G21
                  I change my settings on my 2014 G21 all the time. All settings list NCRS/NSS. MPH. My waves are generally very clean. I do think the Malibu and mastercraft waves look cleaner and smoother but aren't as fun/good for surfing. Always hard to tell as changing waves tough and I have 100x the time on my wave vs. friends' boats.
                  Empty belly - 100% both rear. 3/2 11.2 This makes a steeper wave and better for airs and higher end tricks. Good push at rear of wave.
                  I generally like all 100% - 3/3 11.0. More versatile wave. Good all around wave for most.
                  For longboarding (9'0) and cross-stepping etc...all 100% 0/0 12.0 -12.2 mph
                  Belly at 50%, rear 100% 5/2 11.5 mph makes a steep wave on regular side that's fun to smack surf style.
                  I do have 150 pounds under port side across driver to balance driver weight.
                  Passenger sits on surf side.
                  I rarely have mismatched weight in rear but we jump the wake a lot plus switch riders so don't empty and fill between. I have not experimented with that much.
                  One thing I really like about the G21 is you can modify the wave a lot. I haven't played with my friend's G23 enough but seems like she can't modify her wave as much (or at least hasn't learned how).
                  Starboard wave definitely naturally steeper than port wave. Both great waves though.
                  Dave
                  • plsweet
                    • Mar 2020
                    • 2
                    • IL
                    • 2020 G21
                    Dave, these are great suggestions
                    • BasaltRMK
                      • Apr 2020
                      • 316
                      • Basalt, CO
                      • 2024 SAN G23 2020 SAN G21 (Sold) 2018 SAN G21 (Sold) 2015 Tigé R20 (sold) 1972 MFG Gypsy-15 Tri-hull (sold)
                      So interesting how different the setups are that people use. Here’s what we have on our 2020 G21:
                      Belly: 85%
                      Star: 85%
                      Port: 100%
                      NSS: 1
                      NCRS: 5
                      Speed: 11.2 - 11.4
                      2020 SAN G21
                      2018 SAN G21 (traded in)
                      1972 MFG Gypsy-15 (sold)
                      • BasaltRMK
                        • Apr 2020
                        • 316
                        • Basalt, CO
                        Sorry, hit send early...
                        Lead:
                        50 # rear port locker
                        100# middle port seat
                        50# port passenger seat
                        50# port bow
                        100# middle starboard seat
                        Wave is huge, steep, clean, with huge push. Will play around with some of the other suggestions but feel like we’ve got it dialed.
                        2020 SAN G21
