Originally posted by Ckowals1
View Post
We were above 15' of water for sure, I have read that deeper than 20' may even been the number. I may just be going too slow since i have tried anything from a 4'4" to a quad 5'9". I am 5'10" 170lbs and surfed my 210 close to the platform but could go down the lake no problem. What is your hydrogate at or havent seen much difference? Are you all ballast full and surfing port side?
My boat's ballast and speed setup is pretty much similar, and I'd say it is a big wave with tons of push. I tun at 11.2 mph to get a little longer wave (slower speed = not as long, but a taller wave).Originally posted by dhanni848 View PostNew to the 230 (just picked mine up Friday). We did some surfing and it may be me but having a little issue staying in the pocket or finding it really. 2013 with NSS, 1100s in rear lockers, factory belly with bow bag piggybacked off that. Not sure of the size on the bow but fills the entire bow.
I have tried from 10-11 MPH with all full. We all surf port. It does have hydrogate as well and we had at 0. What are some suggestions for me? Open to opinions other than a bunch of sacks in seats or floors!
I have noticed a huge diference in push (ability to stay with the wave) when the depth of water is below 15'.
Additionally, riding on a board that is small for your size (height and weight), being positioned too far back on the board, and having too much weight over your back foot are all things that will make it hard to keep up with the wave
Leave a comment:
Leave a comment:
Following up on my post. I contacted FAE and was notified that for an additional 20$ they can include a thru-hull bracket that would eliminate the need for the rubber connector, as well as eliminate the need for the support bracket. Looks like my problem is solved!Originally posted by Ckowals1 View PostNot technically surf related as it considers ballast/speed settings. But I wanted to see if anyone here retrofitted the 2014+ Nautique “surf pipe” onto a 2007-2011 236/230 hull.
i have an 08 230 that really kicks up a lot of exhaust fumes when surfing. (1100 fat sacs in each rear locker. Stock belly ballast + 675lb arrow sack).
when the rear 1100s are filled more that 2/3 of the way and I have more than 2 people In the boat, the fumes become more noticeable.
considering the FAE, but I don’t like the look of it with the rubber connector. I’d prefer a smoother all metal exhaust.
Leave a comment:
Leave a comment:
I have a 2011 with the EX343 and the 2079 is a game changer compared to the 1235. We get to surf speed almost immediately. We’re running a similar 3,000ish lb load. We lost some top end but I never really use it. I’m glad Wakemakers has started recommending it. Info on using the prop in a 230 was pretty hard to find a couple of years ago.
Leave a comment:
In case anyone had thoughts of trying it...I changed my stock prop out for an Acme 2079, which has a lower pitch. It’s the model that Wakemakers lists for 230 at high altitude or with heavy ballast. I have a 2015 230 with ZR409. I’m at 3100 pounds of ballast, and with the stock prop, if everyone was sitting at the back of the boat or if we had a bigger crew, the boat would take longer to achieve surf speed than I liked and sound like it was struggling (maybe cavitating?) The new prop improves launch a ton with very smooth and easy acceleration as well as faster time to surf speed. You can certainly notice the higher RPM at cruising speeds, but we are only at those speeds going to and from our surfing and coving spots. I essentially never top it out, but I tried just for comparison, and top speed went from around 41 MPH to around 37-38 MPH.
Leave a comment:
Has anyone converted the nautique pro ballast bags (fat sac original 400 pounders) into on-board ballast for extra weight? I tried to unscrew the ballast connectors but they won’t come off. Has anyone been able to adapt the bags with fittings and a tsunami pump?
Leave a comment:
Few tips for people with factory pro ballast who have not upgraded yet. First off 10 feet of water depth is needed or the wave won’t form, it took me a while to figure this out (shallow lake).
Ballast: port full, starboard 95%,front/bow ballast 70%. NSS 1, Hydrogate 1. I’ve found that dumping 250 Pounds out of the bow really helps the wave. It really adds some push and let me surf further back off the platform.
Leave a comment:
PM sent.Originally posted by Hurley View PostHi Guys, I've got a 2019 230, surf on starboard side. Have the factory 400 lb pro ballast bags and 500# of lead (300 starboard & 200 port) under the bags. Found recently that when it's just my wife & 9 y/o in the boat having the back tanks full and front tank reduced to 30% made a huge difference. It does bring the bow up a bit but the wake is surprisingly much better -- tall and long. Surf at 10.9 mph, NSS 4, NCSS 3. I can ride it waaaay back at this setup.
Wanted to ask where you guys are getting these 650# bags from? I don't see them on Wakemakers. I'm so done with the lead in the back! My boat porpoises up and down like crazy when running empty tanks at higher speeds. I also think the lead messes with the wake for novice wakeboarders at slower speeds. So, I'm hoping to get rid of some of that lead and have a net-zero tradeoff with these bags. Thanks for helping to find them. I also have the trays and no way can I get rid of those. Storage space is too limited on the 230. thanks
Leave a comment:
The install is very straightforward. My biggest challenge was working with those STIFF hoses. Bring a hair dryer or similar, otherwise its near impossible to get them on and off. Particulalrly because you are working in a tight space and it can be challenging getting leverage.
Leave a comment:
I ordered the 650s and the divider panel, I am waiting for them to arrive. I look forward to your installation video, sounds fairly straightforward though. Thanks.Originally posted by SkimRider View PostI asked about the trays fitting with the 650's a few weeks ago. I went ahead and got them and installed them. I was going to say exactly what PapaBear said. That is spot on in my experience.
The only thing I would add, is that I did the install on just the port side first and went out and tested it. I left the both trays in and the lids closed and filled port and starboard ballasts. Once full, the boat listed to the port side fairly heavily. So, my conclusion is that even with the trays in, you are getting a fair amount of additional ballast over the stock Pro ballast. Hard to say how much.
I'm pretty excited, because I had been bringing an extra bag for the floor out when it was just two of us. Now, I don't need to do that anymore! Have not added any lead yet, but, I may put some up front.
Regarding the install, it wasn't too bad at all and I am not very "handy". I'm actually making an install video for WakeMakers.
I'm wondering about the dividers too. One of my horizontal bars has bowed slightly.
Leave a comment:
https://www.wakemakers.com/nautique-...st-system.html
Link says 750 but these are the product. You may have to select your boat specifics from the menu.
Leave a comment:
Leave a comment:
Agree that the install is straightforward. If I remember correctly, it’s clipping the factory zip ties out, then swapping the factory fill and drain tubes from one bag to the other with hose clamps. I think I remember the hardest part being pulling the factory fittings out of the hoses...mine were just kind of stuck in there.Originally posted by SkimRider View PostI asked about the trays fitting with the 650's a few weeks ago. I went ahead and got them and installed them. I was going to say exactly what PapaBear said. That is spot on in my experience.
I would say the divider reinforcements are a necessity. I did mine at the same time as the bags as I didn’t want to wait for them to possibly fail. However, I initially only reinforced the panels but didn’t add a second pin to the rear channel. I then had an episode where the divider lifted in the rear channel and came out of the lower channel and we likely surfed all day in this state. When I discovered it, the divider was badly bowed in the non reinforced plane. With some hot days, sunlight, and weight, I got it back in shape. I have since drilled a new hole through the rear channels and through the divider through which I place a bolt and wing nut to prevent any lifting.
My divider reinforcements are made from cheap L-channel aluminum and oriented vertically, 3 on each (engine) side of the dividers with a few nuts and bolts each to hold them to the divider. They’ve worked great. You just have to limit their length more than you’d expect to allow room for the lower channel engagement below and room to clear the fiberglass and gel coat rim of the locker above as you slide them into the side channels.
Leave a comment:
Leave a comment:
