I was searching the forum for replacing the steering cable on my 2006 and came across some good posts. One question I have is can the rear floor panel in the middle be removed to gain access, not the one panel the flips up to access the drain plug, but the one in front of that one.
Also, for those that trailer and take the drain plug out, do remove the rear seat each time you take it out and install it?
