The dual swivel rack system on our 2017 Super Air Nautique (manufactured in 2016) BUT it isn't quite wide enough to fit our wake surf boards. I was hoping to upgrade for my husbands birthday but could use some help since I don't know much about the boat. I've seen replacement tines/forks (instead of buying the entire rack) and that seems like it's the easiest way to go if I want to stick with the existing swivel rack system. How do I know what will be compatible with our system? There's a sticker that says "Correct Craft, Inc Flight Control Tower"
I'd call Nautiqueparts.com and see what help they can offer - both in ID-ing your exact current rack and helping with options.
You can get a 10% board discount by referencing code PND at the time of order.
https://nautiqueparts.com/
Hope this helps!
Bellevue WA
Thanks - the guy at nautique parts was helpful and super friendly but a further call to TJ at Roswell Marine answered all my questions and ensured I ordered the correct part. At this time, you can't order just the replacement surf / wake tines for the swivel rack. They make the tines but the bolt pattern isn't compatable with Nautique backing plate on the swivel racks that came on this tower. The slightly more pricy solution is to order the Roswell Elite Surf Wake Rack (or Dual Surf Rack). This unit comes with a backing plate as well as the tines and the whole piece replaces the existing Nautique one. TJ even told be that I'd need a 3/32 and 5/32 Hex key to swap it out. Great customer service!
Glad this got you on the path for answer!
Sent from my Pixel 7 using Tapatalk
Bellevue WA
